Big Daishowa launches its fourth Annual Tools for Schools Program
Now in its fourth year, the Tools for Schools program from Big Daishowa continues to grow, supporting the next generation of manufacturers.
November 4, 2025
Now in its fourth year, the Tools for Schools program from Big Daishowa continues to grow, helping to support the next generation of manufacturers.
From November 3, 2025–January 30, 2026, Big Daishowa will again donate a tooling certificate valued at 20 percent of every qualifying order to the customer's school of choice through the Tools for Schools program. Schools can redeem certificates for any Big Daishowa products, including best-in-class tool holders, boring tools, cutting tools, workholding products and presetters.
In the first three years, Big Daishowa has issued nearly $70,000 in tooling certificates to high schools, vocational schools, colleges and universities. According to Jack Burley, President/COO of Big Daishowa, this aligns with the company's mission to nurture skilled workers for the future.
"We're committed to preparing the next generation of manufacturers for success. This program helps inspire students by giving them the confidence, skill and experience to work with the same precision tooling they'll use in their careers," said Burley.
To participate in the program:
  • The qualifying minimum order is $5,000 (earning a $1,000 tooling certificate).
  • Place the order through your local distributor and request "Drop ship from Big Daishowa."
  • Reference "PROMO-BD-SCHOOLS" as a line item on your order.
Big Daishowa offers a range of precision tooling, workholding, and tool management systems aimed at reducing both the overall process time and the cost per part.
Popular products include face mill holders, end mill holders, collet chucks, angle heads and tapping adaptors. The world-leading Kaiser Boring System, high-performance Sphinx Drills and Unilock Workholding systems are also available, as are CAT, BT, HSK and BIG Capto systems.
If your machine is equipped with a Big-Plus spindle, remember that Big Daishowa is the officially licensed provider of Big-Plus tool holders in North America. Don't accept any substitute dual contact products on your valuable machines.
  • tapping
    Machining operation in which a tap, with teeth on its periphery, cuts internal threads in a predrilled hole having a smaller diameter than the tap diameter. Threads are formed by a…
  • boring
    Enlarging a hole that already has been drilled or cored. Generally, it is an operation of truing the previously drilled hole with a single-point, lathe-type tool. Boring is essenti…
  • collet
    Flexible-sided device that secures a tool or workpiece. Similar in function to a chuck, but can accommodate only a narrow size range. Typically provides greater gripping force and…
